Originally Posted By: Camprunner
Today in WM I ran into a friend in the oil section and he was buying several quarts of Shell Rotella T synthetic 5w40 for his Subaru WRX I asked him doesn't your car recommend a 5 or 10w30? He said yes but he said many WRX guys like to run this?
Is this a common oil for Subaru WRX guys? Does the 4w40 show good UOA?
Yes, very common as others have said.
Do you know if the WRX is 2015 or earlier? The older WRX's with the EJ engine are more prone to bearing problems on thin oil. The STI still uses the older EJ engine and there have been several bearing failures even on late model, unmodified STI's for the past couple of years (possibly a manufacturing issue?).
The newer engine in the 2015 and later WRX has direct injection and many enthusiasts are running GF-5 and lower SAPS ACEA C3 oils in hopes of mitigating intake valve deposit issues. For the most part, these engines seem to be doing ok with high fuel dilution (2-5%) and thin oil. Note that Subaru Japan allows high SAPS 0W-30 and 5W-40 in these newer DI engines.
Here's a very good WRX specific thread where Doug Hillary talks a bit about the history of using HDEO's in petrol cars back before some of us were born.
He does state:
Quote:
Modern appropriately classified lubricants as recommended by the engine's Manufacturer have almost effectively negated their use in petrol engines today IMO.
I think RT6 in a WRX (and among other enthusiasts) became so popular because people wanted a robust oil and something cheap from Wal-Mart. Lately, M1 0W40 and Castrol 0W40 have become a bit more popular among WRX enthusiasts. Probably because they're now more readily available at Wal-Mart these days.
