Mater Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
86 registered members (555, 2010Civic, 3311, A1O, 12 invisible), 2,069 guests, and 57 spiders.
Topics286,156
Posts4,903,171
Members67,565
Most Online2,967
Mar 10th, 2019
Page 1 of 5 1 2 5
Fram Ultra Synthetic Cartridge Problem #4119996
06/09/16 10:20 PM
06/09/16 10:20 PM
Northern Arizona
funflyer Offline OP
funflyer  Offline OP
Northern Arizona
Decided to start a new thread instead of adding my findings to some of the other threads concerning the supposed failures of the XG synthetic cartridge filters. My curiosity got the best of me after reading the below threads and I suspected that an undersized ID of the end caps might have contributed to or possibly caused the media to separate from them, either during installation or removal. That's exactly what I found with five new XG10358 cartridges. I purchased four from the net, checked another in a local store and found all to have the same issue. The picture of the housing cap center tube was blurry so I didn't include it but the tube OD measured 1.095" - 1.103".
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3434977/Fram_Ultra_FAILURE
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3411091/1
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3930160
Here the filter is just started on the housing cap. It was very tight and I didn't try to push it any farther or I could have easily damaged the media.
Here are the specs from Fram's website. Notice the ID should be 1.108"
Here's the ID of the first of five I checked. The other four were almost exactly the same. Caliper showed 1.091" - 1.093"
Compared to the Wix filter. The Wix measured 1.112" and dropped right into the cover.
OEM Toyota filter measured @ 1.105".
[/b][b][/b][b][b][/b]
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
Re: Fram Ultra Synthetic Cartridge Problem [Re: funflyer] #4120009
06/09/16 10:34 PM
06/09/16 10:34 PM
Chicago, IL
Brybo86 Offline
Brybo86  Offline
Chicago, IL
Call Fram and get a free filter
08 Honda Accord EX-L 2.4L M1 EP 0w20 153k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 199k
95 Yamaha Jog
Re: Fram Ultra Synthetic Cartridge Problem [Re: funflyer] #4120015
06/09/16 10:39 PM
06/09/16 10:39 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
Good detective work and pictures. I think the Ultra is still on my list for canister filters, but the list of those even is getting smaller. Of your three for me at least, the last one is the best one. This is how copying and not getting it exact ends up. The Wix is a little too loose, the Ultra much too tight, The OE seems to be just right.
Re: Fram Ultra Synthetic Cartridge Problem [Re: funflyer] #4120027
06/09/16 10:50 PM
06/09/16 10:50 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
Fram does list the spec pretty close to correct, must be the machine that makes the hole, or the plastic mold, is out of adjustment. That a number were measured is very good proof something is haywire.
Re: Fram Ultra Synthetic Cartridge Problem [Re: funflyer] #4120033
06/09/16 10:55 PM
06/09/16 10:55 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
The Fram's end cap ID looks to only be on the very lips of the end caps. If they are a bit flexible, and if lubed up with oil does that help the filter slip over the metal center tube?
Re: Fram Ultra Synthetic Cartridge Problem [Re: Brybo86] #4120048
06/09/16 11:08 PM
06/09/16 11:08 PM
Northern Arizona
funflyer Offline OP
funflyer  Offline OP
Northern Arizona
Probably get more with the same issue. I won't speculate on whether Fram has a good quality management system in place or not but the customer should never be the one to find defective products.
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
Re: Fram Ultra Synthetic Cartridge Problem [Re: ZeeOSix] #4120054
06/09/16 11:18 PM
06/09/16 11:18 PM
Northern Arizona
funflyer Offline OP
funflyer  Offline OP
Northern Arizona
The end caps are a hard plastic material with zero flex. Oil was no help. Even if someone manages to squeak one on the center tube, what happens when they try to remove it? What about the highly trained Jiffy Lube tech that removes the filter and the end stays in the housing cap? I can see someone easily leaving it in there and installing a new filter on top of it
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
Re: Fram Ultra Synthetic Cartridge Problem [Re: funflyer] #4120059
06/09/16 11:22 PM
06/09/16 11:22 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
I would buy the Yota filters.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Fram Ultra Synthetic Cartridge Problem [Re: funflyer] #4120081
06/09/16 11:53 PM
06/09/16 11:53 PM
VA
bvance554 Offline
bvance554  Offline
VA
The Pronto cartridges that I get for $1.83 each on Rockauto look better than both of those filters.
Re: Fram Ultra Synthetic Cartridge Problem [Re: funflyer] #4120099
06/10/16 01:36 AM
06/10/16 01:36 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
If the end caps are hard plastic, then yes this could definitely be an issue on some vehicles if there's an interference fit on some vehicles.
funflyer - what vehicle were you measuring the metal center tube on?
Suggest emailing Jay (aka Motorking here) with a link to this thread so he can see it and pass along the info within Fram for possible improvements.
Here's his email: [email protected]
Re: Fram Ultra Synthetic Cartridge Problem [Re: funflyer] #4120255
06/10/16 08:08 AM
06/10/16 08:08 AM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
Very clear reporting, Fram says 1.108" is the spec for the hole, but they made the hole 1.091". As was said.
Re: Fram Ultra Synthetic Cartridge Problem [Re: funflyer] #4120262
06/10/16 08:19 AM
06/10/16 08:19 AM
The Orca
quint Offline
quint  Offline
The Orca
I recently did oil changes on my dads Corolla and my sisters Highlander using Ultra cartridges and both were very tight as well.
Re: Fram Ultra Synthetic Cartridge Problem [Re: goodtimes] #4120281
06/10/16 08:45 AM
06/10/16 08:45 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Exactly! Why should there be any extra work for the consumer when this should be a 'direct fit replacement'. Great detective work and bonus points for conducting this on more than one filter. In essence showing that this batch, at least, is defective.
18 KIA Sportage 2.4 AWD
M1HM 10W30, OEM
13 Hyundai Santa Fe Sport 2.0T
PPeL 5W30, OEM
Re: Fram Ultra Synthetic Cartridge Problem [Re: funflyer] #4120292
06/10/16 08:59 AM
06/10/16 08:59 AM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
Don't know what the oil inlet side looks like, but the OE will allow oil to flow into the pleats more directly instead of going around the end cap. Depends on how close the end cap is to the inlet base, if it could be an issue.
Re: Fram Ultra Synthetic Cartridge Problem [Re: ZeeOSix] #4120323
06/10/16 09:33 AM
06/10/16 09:33 AM
Northern Arizona
funflyer Offline OP
funflyer  Offline OP
Northern Arizona
It's a 2016 Toyota Prius. Cap is p/n 15620-37010, same one used on Corolla, Matrix and Scion. I'll shoot Jay an email today.
Actually the Fram and Wix both are very well constructed. Their synthetic media is far superior to most others available. Are Pronto filters still Premium Guard? There might be a good reason they're dirt cheap.
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/1736036/1
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
Page 1 of 5 1 2 5
