"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
transmission fluid and filter exchange
by Dennisistheman. 09/22/18 04:53 PM
Why people should change oil+filter!
by 53' Stude. 09/22/18 04:50 PM
Household lubricants (general purpose) differences
by 92saturnsl2. 09/22/18 04:35 PM
debris in my engine oil--what to do?
by Jasper8146. 09/22/18 03:50 PM
Is this seal bad?
by parshisa. 09/22/18 03:44 PM
Leather Masters Protection Cream review....
by gregk24. 09/22/18 03:13 PM
Aisin WS
by RodneyM. 09/22/18 03:11 PM
Husqvarna trimmer questions
by BrianF. 09/22/18 02:51 PM
Uber Self-Driv Death: Disabled Pedest Avoidance!!!!
by oil_film_movies. 09/22/18 02:29 PM
Question on Backlight setting on LED tv's
by LoneRanger. 09/22/18 02:16 PM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
88 registered members (53' Stude, 55hambone, 87sammy, AP9, 928, 8 invisible), 1,602 guests, and 41 spiders.
Topics290,845
Posts4,851,358
Members66,040
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
Half an Oil Change? #4021490
02/25/16 02:16 PM
02/25/16 02:16 PM
On the road Midwest
Ihatetochangeoil Offline OP
On the road Midwest
I just did UOA and got my report. I would post it, but BITOG doesn't accommodate posting pdf files, and I'm too lazy to manually enter all the data. Getting to the point, my particle count is 14/13/11 compared to my baseline sample of new oil having 17/16/13; so my oil is about 8 times as clean as new oil, all of my wear metals look excellent and my TBN is well within limits...
However, I don't think my air filter is as good as my oil filtration; I've got 30 ppm silicon. (Blackstone and other labs start caution at about 20 ppm Si.). Since I've run the oil only 8K, I've used (and drawn out samples) consisting of almost half a quart. I've got a valve mounted inline to draw samples from, so, I thought, why not "bleed" off a quart and top up with new oil? This should slightly lower my silicon count and raise my TBN.
Having already done this, I ended up topping up 2 new quarts and I'm now 100% full on a 5 quart system. Anybody ever heard of half an oil change? Thoughts? Comments? Why did I save HALF my oil? Answer: Because it's much cleaner by particle count than what comes out of the bottle as new.
2003 Lesabre
2004 Lesabre
2004 Impala
If ur NOT doing UOA then you're throwing away good oil or your engine is already damaged. Choose.
Re: Half an Oil Change? [Re: Ihatetochangeoil] #4021492
02/25/16 02:22 PM
02/25/16 02:22 PM
European Union
Atesz792 Offline
Atesz792  Offline
European Union
That's basically what an oil burner does by default. Partial oil "changes" all the time.
2004 Suzuki GS500F
2006 Renault Mgane 1.5 dci
Re: Half an Oil Change? [Re: Atesz792] #4021495
02/25/16 02:26 PM
02/25/16 02:26 PM
On the road Midwest
On the road Midwest
Yes, but let's see what happens in the next several thousand miles. I do not leak or burn oil and now have clinically clean oil.
2003 Lesabre
2004 Lesabre
2004 Impala
Re: Half an Oil Change? [Re: Ihatetochangeoil] #4021501
02/25/16 02:31 PM
02/25/16 02:31 PM
Minnesota
2010Civic Offline
2010Civic  Offline
Minnesota
Are you saying the new oil you put in the engine is dirtier than what you take out?
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Honda oil filter
58,500 miles
Re: Half an Oil Change? [Re: 2010Civic] #4021504
02/25/16 02:33 PM
02/25/16 02:33 PM
On the road Midwest
On the road Midwest
Yes. But I purposely drained a quart to lower my Si ppm and raise the TBN.
2003 Lesabre
2004 Lesabre
2004 Impala
Re: Half an Oil Change? [Re: Ihatetochangeoil] #4021505
02/25/16 02:34 PM
02/25/16 02:34 PM
SANTOS, BR
Pontual Offline
Pontual  Offline
SANTOS, BR
What you think it's done at quick lubes? Kiddo.
Re: Half an Oil Change? [Re: Ihatetochangeoil] #4021507
02/25/16 02:38 PM
02/25/16 02:38 PM
On the road Midwest
On the road Midwest
Surely you jest. No one at a quick lube will touch my vehicle. You can do what you wish, and I'll do as I please. Thank you. BTW, try to find anyone at any "quick lube" that has even heard of ISO 4406.
The oil in my car with 8K on it is cleaner than any oil in any car on a dealer lot.
2003 Lesabre
2004 Lesabre
2004 Impala
Re: Half an Oil Change? [Re: Ihatetochangeoil] #4021523
02/25/16 02:52 PM
02/25/16 02:52 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Let me fix that for you:
I just did UOA and got my report. I would post it, I'm too lazy to take a screen shot and host it on a free image hosting service.
Fixed grin2
also bitog encourages posting the UOA as a CODE so its still here in 5 years as pictures seem to come and go. Takes aprox 2min.
Re: Half an Oil Change? [Re: Rand] #4021573
02/25/16 03:56 PM
02/25/16 03:56 PM
Lima, Ohio, USA
earlyre Offline
earlyre  Offline
Lima, Ohio, USA
Fixed grin2
basically, copy this and replace the data points with yours:
Code:
OIL             GC0w30   GC0w30
MILES IN USE    4.4k     4.6k
MILES           152.5k   148.1k
SAMPLE TAKEN    10/27/07 7/21/07
ALUMINUM        2        3
CHROMIUM        0        1
IRON            12       17
COPPER          14       13
LEAD            22       19
TIN             0        0
MOLYBDENUM      6        18
NICKEL          0        1
MANGANESE       0        0
SILVER          0        0
TITANIUM        0        0
POTASSIUM       6        10
BORON           5        12
SILICON         7        9
SODIUM          19       24
CALCIUM         1866     2013
MAGNESIUM       525      424
PHOSPHORUS      842      797
ZINC            1082     1041
BARIUM          0        0
INSOLUBLES      0.4      0.3
WATER           0        0
FLASHPOINT F   415      395
SUS VIS 210F   66.8     67.7
cSt @ 212F     12.11    12.33
Mine:
09 Mercury Sable : 6qts AutoQuest(Meijer/Warren) 0w20, WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts VWB 5w30,WIX 51394
Re: Half an Oil Change? [Re: earlyre] #4021574
02/25/16 03:59 PM
02/25/16 03:59 PM
On the road Midwest
On the road Midwest
Thanks Rand; I'll get to work and try that. Results or **** coming.
2003 Lesabre
2004 Lesabre
2004 Impala
Re: Half an Oil Change? [Re: Ihatetochangeoil] #4021587
02/25/16 04:15 PM
02/25/16 04:15 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
The air filtration is the most important filtration.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Half an Oil Change? [Re: Ihatetochangeoil] #4021593
02/25/16 04:22 PM
02/25/16 04:22 PM
On the road Midwest
On the road Midwest
Here goes, let's see what happens...
OIL AMSOIL 5W30
MILES IN USE 8.0k
MILES 67k 67k
SAMPLE TAKEN 02/19/16
New Oil
ALUMINUM 1 1
CHROMIUM 1 0
IRON 16 1
COPPER 18 0
LEAD 02 0
TIN 1 0
MOLYBDENUM 137 147
NICKEL 0 0
MANGANESE 0 0
SILVER 0 1
TITANIUM 0 0
POTASSIUM 0 4
BORON 134 207
SILICON 30 6
SODIUM 30 3
CALCIUM 3059 3862
MAGNESIUM 13 14
PHOSPHORUS 595 690
ZINC 667 788
BARIUM 0 0
INSOLUBLES N/A N/A
WATER <.1 <.1
FLASHPOINT F N/A N/A
SUS VIS 210F N/A N/A
cSt @ 212F 11.3 10.4
ISO 4406 14/13/11 >4 137um >6um 74 >10um 27 >14um 12 >21um 4 >38um 0
Baseline 17/16/13 >4 794um >6um 432 >10um 161 >14um 73 >21um 24 >38um 3
I have my testing done at Oil Analysers; they do not provide Insolubles, Flashpoint or SUS VIS 210F; but I do have particle counting done.
Edit: this is not at all what I posted; nor did it come out worth a ****. I tried.
2003 Lesabre
2004 Lesabre
2004 Impala
Re: Half an Oil Change? [Re: earlyre] #4021607
02/25/16 04:34 PM
02/25/16 04:34 PM
On the road Midwest
On the road Midwest
Earlye, Thanks for the insults and no help. I did what you suggested and got nowhere. Good thing I'm doing my UOA for my own info and not to impress strangers.
2003 Lesabre
2004 Lesabre
2004 Impala
Re: Half an Oil Change? [Re: Ihatetochangeoil] #4021626
02/25/16 04:53 PM
02/25/16 04:53 PM
USA
mk378 Offline
mk378  Offline
USA
Code:
OIL AMSOIL 5W30
MILES IN USE 8.0k
MILES 67k
Element  Used Oil New Oil
ALUMINUM     1       1
CHROMIUM     1       0
IRON        16       1
COPPER      18       0
LEAD         2       0
TIN          1       0
MOLYBDENUM 137     147
NICKEL       0       0
MANGANESE    0       0
SILVER       0       1
TITANIUM     0       0
POTASSIUM    0       4
BORON      134     207
SILICON     30       6
SODIUM      30       3
CALCIUM   3059    3862
MAGNESIUM   13      14
PHOSPHORUS 595     690
ZINC       667     788
BARIUM       0       0
INSOLUBLES N/A     N/A
WATER      <.1     <.1
ISO 4406 14/13/11 >4um 137 >6um  74 >10um  27 >14um 12 >21um  4 >38um 0
Baseline 17/16/13 >4um 794 >6um 432 >10um 161 >14um 73 >21um 24 >38um 3
Re: Half an Oil Change? [Re: Ihatetochangeoil] #4021644
02/25/16 05:11 PM
02/25/16 05:11 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
If your using Windows, open the PDF, use the snipping tool cut the data you want from the pdf and paste into paint. Then save as a JPEG and post that.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Page 1 of 3 1 2 3
