Originally Posted By: Jake777
Yes it does per the first link MolaKule posted to the Moly section on this site says this. This is why to my understanding I don't know if anything but Moly does this and thus if it's lacking then it's lacking.
"This coating effectively fills in the microscopic pores that cover the surface of all engine parts, making them smoother. This feature is important in providing an effective seal on the combustion chamber. By filling in the craters and pores Moly improves this seal allowing for more efficient combustion and engine performance."
The first link was posted by krismoriah72, not Molakule. Also, that link is discussing Molybdenum Disulfide, which is not used generally in motor oils as per Molakule's post in the 2nd link provided:
Originally Posted By: Molakule
There seems to be some continuing confusion over moly or molybdenum additives in lubricants. Moly in whatever form is a primarily a friction reducer.
There are generally three types of moly used to reduce friction:
1. SOLID, Powdered MoS2 used a solid lubricant, primarily used in locks and suspended in greases.
2. colloidal molybdenum disulfide which means MoS2 suspended in an oil. Particle size may vary from micrometers (1X10^-6) to tens of nanometers (1X10^-9) meters in size. The primary application was in gear lubes (except for manual transmissions) and greases.
3. The soluble moly may be in the form of molybdenum dithiocarbamate or MoDTC, molybdenum dialkyldithiophosphates or MoDTP, and molybdenum dithiolate or MoDTH. These chemistries are most used in liquid lubricating oils.
Molybdenum dithiophosphate or MoDTP is used primarily in hydraulic oils.
MoDTH is used in specialty applications.
Molybdenum dithiocarbamate or MoDTC is now the most often used form of moly in motor oils and gear lubes, except for Manual Transmissions. MoDTC also acts as an anti-oxidant and is therefore classified as a Multi-functional additive.
At various treatment rates and depending on the exact chemistry, MoDTC can be a friction modifer, an AW additive, or an EP additive, or all three.
That first link about Molybdenum Disulfide is saying that (this) moly fills the microscopic pores making the surfaces smoother. This aides in chamber/ring seal. It says nothing about scoring, which certainly isn't microscopic, nor about RESTORING compression in an engine with scored cylinders.
