So today, I just changed the oil for the first time. THe oil filter is hidden to the side by flap, and under the hood, I saw the lower and hi port for air conditioning,but I was curious as to whether or not the CVT had a drain plug or not and whether or not there was one for the radiator/coolant too. If so, where are they and can you show some pictures of them? Thanks. I saw one potential candidate for a transmission drain plug, it was very wide/fat of a hex under the transmission pan, but wasn't sure if that was it. And if there is a transmission or cvt drain plug, how many mm or sae inches are they? I saw the transmission pan, and it had the bolts, and i know with automatic trans, you can "drop the pan" and change the filter and gasket,but does this CVT have a transmission filter and is it replaceable or serviceable or no? ANd is there a transmission gasket? I'm guessing there are because there is a transmission pan. Thanks.
Speaking of gaskets, on a 6 cylinder ford taurus 09, you have to replace the upper manifold gasket when you change the spark plugs, or can you save that gasket since you take the manifold off? Thanks.
