Beard care in cold weather?
by pandus13 - 11/15/19 08:39 AM
Door Sill protection for new car - which one?
by henni - 11/15/19 08:18 AM
Exterior Home Security Cameras?
by Gebo - 11/15/19 08:13 AM
5w-20 ok for GMC 6.2l ?
by jdw1222 - 11/15/19 08:02 AM
M. Defender vs Cont. TrueContact Tour?
by lukejo - 11/15/19 07:53 AM
Alternative for Lexus Toyota WS
by Joephu - 11/15/19 06:19 AM
F1 - 2019 Brazilian Grand Prix
by gofast182 - 11/15/19 06:10 AM
2019 i30 Nline 1.6T and first service (1500km)
by rov137 - 11/14/19 10:11 PM
Garbage Disposal Replacement
by bunnspecial - 11/14/19 09:58 PM
Nest thermostat
by miden851 - 11/14/19 09:06 PM
2011 G37X
by maverickfhs - 11/14/19 08:27 PM
Recommendations for oil filter
by dawgn86 - 11/14/19 07:38 PM
2001 Subaru Outback $2,300 OBO
by 14Accent - 11/14/19 07:16 PM
Brake Friction Code List
by 92saturnsl2 - 11/14/19 07:14 PM
Accord reached a milestone today!
by mclasser - 11/14/19 06:59 PM
Is an alignment absolutely needed after new tires?
by SouthDakotaDad - 11/14/19 06:11 PM
Redline Professional Series 5w20
by burla - 11/14/19 06:00 PM
Backup Camera
by George7941 - 11/14/19 05:26 PM
'11 Prius 15k OCI Amsoil 0W-20
by mdv - 11/14/19 05:16 PM
DjS71, Akhunter, rov137, Dorisy, DesktopDave
69870 Registered Users
118 registered members (14Accent, andyd, 4WD, Aero540T, 2015_PSD, 92saturnsl2, 16 invisible), 1,733 guests, and 25 spiders.
Topics297,435
Posts5,115,671
Members69,870
Most Online3,589
Nov 2nd, 2019
Oil Filter Torque Figures #3147527 10/07/13 06:33 AM
M
Merkava_4 Offline OP
M
I always thought it would be cool if we had torque figures for our oil filters. It would be so much nicer than worrying about getting the filter too tight or too loose by hand. On small piston engine powered aircraft like a Cessna 182, the oil filter will have a nut on the end like a K&N filter has. Teledyne Continental specifies a range of 192-216 inch pounds for disposable type oil filters on their engines:
Teledyne Continental PDF
I'm wondering how 200 inch pounds would be for an ACDelco PF47.
Re: Oil Filter Torque Figures [Re: Merkava_4] #3147530 10/07/13 06:37 AM
G
gregk24 Offline
G
I just tighten as hard as I can by hand and call it a day.
2012 Honda Accord EX-L K24z3
59,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
51,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Oil Filter Torque Figures [Re: Merkava_4] #3147541 10/07/13 06:49 AM
T
Tegger Offline
T
Honda OEM 15400-PLM-A02 is tightened to 10-14 Newton-meters (about 8-10 ft-lbs). Says so right on the filter.
2013 Toyota RAV4 - 88,000 miles - Toyota 0W-20, Toyota filter
Re: Oil Filter Torque Figures [Re: gregk24] #3147548 10/07/13 06:56 AM
B
bigt61 Offline
B
+1 Maybe not quite "as hard as I can", but good and snug with a clean grip. No torque wrench needed.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: Oil Filter Torque Figures [Re: Merkava_4] #3147637 10/07/13 08:48 AM
stephen9666 Offline
I think my Sonata's factory service manual does have a torque spec for the oil filter.
I'm super serious about torquing things to spec, but that's one I skip. I just tighten it by hand to the normal 3/4 - 1 turn and call it a day.
Re: Oil Filter Torque Figures [Re: bigt61] #3147641 10/07/13 08:52 AM
W
webfors Offline
W
^ This
17 Cadillac ATS 2.0T, Edge D1G2 5w30, Champion COS10590
17 Dodge GC, VWB 5w30, Mopar MO-349
18 DL1000XT, Valvoline Dino 20w50, Suzuki OEM OF
Small engines; RT5 10w30
Re: Oil Filter Torque Figures [Re: Merkava_4] #3147648 10/07/13 08:56 AM
surfstar Offline
I use my Torque Wrist (TM) - hasn't failed me yet.
Re: Oil Filter Torque Figures [Re: Merkava_4] #3147680 10/07/13 09:26 AM
N
nitehawk55 Offline
N
Yep , hand tighten here too . Make sure you oil up that new seal or they sure don't come off with your hand though .
05 Ford Five Hundred AWD 3.0 DOHC V6 CVT tranny
Re: Oil Filter Torque Figures [Re: nitehawk55] #3147764 10/07/13 10:47 AM
W
Whimsey Online Content
Online Content
W
I dread changing the oil after it was changed by some one else previously. The filter gasket is usually never lubed and the filter is cranked on super tight so the filter usually deforms as you fight trying to get it off. Also the drain plug is so tight you need a breaker bar to loosen it. I was finally able to get on a OCI schedule for our 3 vehicles where I can change them when it's not cold and nasty out side. My days of laying on the cold ground and in snow and slush are long over with smirk . I've gotten too old and arthritic for that anymore.
Whimsey
Re: Oil Filter Torque Figures [Re: gregk24] #3147770 10/07/13 10:54 AM
Clevy Offline
Wow. Hard as you can. If I put an oil filter on as hard as I could by hard it would never come off.
I use one hand. As soon as I feel contact I turn a maximum of 1/3 turn.
I've never had one leak and they come of fairly easily.
2006 Charger RT
Miles x 2 per oil filter
Re: Oil Filter Torque Figures [Re: Clevy] #3147840 10/07/13 11:54 AM
Z
ZeeOSix Offline
Z
I'd think 1/3 turn isn't quite enough IMO. I go for 2/3~3/4 max from when the gasket first hits the seat.
Re: Oil Filter Torque Figures [Re: Merkava_4] #3147901 10/07/13 12:44 PM
L
loveleo Offline
L
If I tighten it with my hand with a glove as hard as I can, usually after one year I cannot get it off with just my hand. Changing once per year using synthetic oil and filter deals from Autozone.
If I tighten it with bare hand as hard as I can and loose it back just a little bit to make sure I can still loose it with my hand. Usually I am fine next year taking it off with hand.
2007 nissan sentra
2005 ford taurus
Nokia lumia 920
Re: Oil Filter Torque Figures [Re: Merkava_4] #3147995 10/07/13 02:12 PM
H
Hosteen Offline
H
The Denso[Toyota too] oil filters have a ring built into the mounting plate that provides a stop to further filter tightening when the gasket is compressed to design specs. Works good. I guess I could use my 1/4" drive inch pound torque wrench with my filter cap tool to torque the filter but have no need to.Never have seen oil filter torque specs for my 04 in the shop manuals.Regards
Re: Oil Filter Torque Figures [Re: Clevy] #3148026 10/07/13 02:33 PM
G
Garak Offline
G
One definitely has to be cautious, depending on filter size and leverage. It's pretty hard to overtighten the filter on the G by hand, being so small of a filter. But, with something like a Chevy small block, if the large filter has thin enough cannister material, one can deform it putting it on by hand if one twists too hard.
Plain, simple Garak.
Re: Oil Filter Torque Figures [Re: Merkava_4] #3149696 10/08/13 07:56 PM
L
LotI Offline
L
The service manual for my Honda VFR800 says 16ft-lbs. That's 196 inch pounds so 200 is a nice round number. I think my old Neon said 20 ft-lbs but that's darn tight.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX http://www.fuelly.com/car/buick/regal_tourx/2019/loti/943992
