Originally Posted By: KrisZ
Originally Posted By: oilcoholic
Nope, I torque the filter to hand tightness and never a problem. Same with the drain plug. I use a 1/4 drive ratchet with a six point socket and torque until it is tight. A few times and you'll get the "feel."
Same here, never had a leak or even a seep, never stripped a drain plug either, but for someone that just starts wrenching on cars a torque wrench is a good idea.
I've changed oil for almost 50 years, and this is the best description of what to do. Just spin on the filter / turn in the drain plug until it's snug, then tighten as follows:
Tighten the oil filter by hand; it should be unnecessary in all but the tightest spaces to ever use a wrench. If you have to tighten the OF with a wrench, just ensure than you don't do it further than the spec. Usually 1/4 turn from "snug" is fine. (It should be obvious, but Nota Bene: this applies ONLY to "spin-on" or "canister" type oil filters, not cartridge filters.
Put your socket on the oil drain plug. I use a ratchet with about a 6" handle. I give it one good tug from "snug" and I'm done. Naturally, you should ensure that the proper washer goes between the plug and the drain pan. Copper is preferable.
This technique makes both the OF and the drain plug easy to get out the next time, and I've never had a leak of any kind. As was mentioned, you just need to develop a "feel" for it. The main point is that these things are not head bolts on a D9 Caterpillar diesel, and don't require heavy torquing.
