Originally Posted By: hounddog
He had proof of oil changes.It was a mess.Valve springs and what not were buried in goo.It had built a dome in the valve cover.Under 25k on the odometer.The Toyota truck he got his wife he hated.It used oil,got poor fuel mileage.He traded it in on a new 03 Dodge SLT 2500 Quad cab 2wd auto etc.His wife and he loved it.Bright red.Wasn't that much more then the Toyota truck but was a LOT more truck with a LOT better fuel mileage.It wasn't until a couple years went by that the KNOWN sludge issues on that Toyota was made.You couldn't give him a Toyota to this day
Let's try and stay factual here. The FACT is that Toyota had two engines during the late 90 - early 00s that
could be prone to sludge, and usually when inadequately maintained. Toyota's biggest mistake, IMO, in responding to the problem (engine changes eliminated the issue in 2002) was in trying to distinguish who had timely changed oil, and who had not. Later, they essentially stopped doing this.
Another fact: I put way more miles on my 01 Highlander than your friend put on his, I changed my oil, with 5k OCIs even, and had no hint of sludge at all, not even varnish. None. Perhaps your friend was not so careful about his maintenance after all...
Look, the original question was:
Quote:
My uncle just told me he picked up a mint 02 highlander with 43,000 miles on it. I was looking around online and it seems as if it falls into the sludger catagory? Is that the case? If so what oil do you folks think would be best for a known sludge engine? I was thinking either PU or maybe even amsoil?
Your "I hate Toyota" rant offered the OP nothing (perhaps before throwing any more stones around this glass house, you should
check out THIS THREAD ) . He already has the vehicle and is asking for an oil rec. Please either
address the OP's question, or move on.
Back to the question at hand. If this is an 02 vehicle, he's probably got one that was made after the corrections (so the whole rant is irrelevant...). Nevertheless, to be perfectly safe, and for peace of mind, I'd stay with a synthetic.
