Hi all, I'm new here and thought I'd start off with a question. I have a BMW Z4 with a warranty that just expired and thought I'd ask you guys for recommendations regarding oil.
The car has been serviced its entire life by the dealer with oil changes, using BMW's high-performance full synthetic 5w30 oil. I did the last oil change with Mobil 1 5w30 15,000 miles synthetic about 6,500 miles ago. It has recently come to my attention that Mobil 1 is not fully synthetic, and that this oil is not recommended by the dealership as a long-life oil.
I want to do my next oil change using Castrol Syntec European Formula SAE 0W-30. Is it okay going from Mobil 1 5w30 to the recommended Castrol euro fully-synthetic 0w30? I don't want to have any lower or upper engine block gasket leaks, because I have read in the past that going from a dino oil (well partially dino in this case) to a synthetic oil can cause that.
Just as a heads up, the oil needs to be fully synthetic; and I guess price isn't really a big deal, but nothing out of control.
1. What kind of vehicle you have
BMW Z4 with 50k miles, M54 engine
2. What your owner's manual says -- not just viscosity, but certifications (look for acronyms like API SM, ILSAC GF-4, etc.) and change intervals as well
"BMW Long-life rating LL-01 Approved Synthetic Oils for the US Market", "Use only oils with an API rating of SM or higher."
taken from the BMW website: BMW recommended oil list
Change internal is 15,000 miles, but I usually change it around 7,500 miles or at least once a year
3. Where you live
NJ, USA
4. How you drive (easy? hard? fast? slow?)
About 80% of the time I'm cruising, 20% of the time I like to drive hard
5. What your daily drive is like (short trips? long trips? city? highway?)
Short trips, mostly city
6. Whether your car has any known problems
No known problems
Thanks in advance!
3. Where you live
NJ, USA
No known problems
Thanks in advance!
