Originally Posted By: bluesubie
I'm lazy so I'll copy my own post from the Forester board.
09rexwagon on nasioc measured the relief valve in the new OEM Fram and he claims that it was 23 psi's. He also measured the Tokyo Roki and claimed that it was not 23 psi's as also stated by SoA.
All that aside, I'll be running the blue can of death for 6-7,500 mile OCI's so I'll advise if I have any problems.
I used to always bash Fram because it was fashionable too. Although my dad has run Fram's for a long time and keeps his GM trucks for 250k-350k miles. I know there are a lot of reports of them exploding, although I have not heard of any problems specifically relating to the Subaru OEM's.
[crosses fingers]
From the bottom of this page
Quote:
Bad news guys. I just cut open the black Tokyo Roki oil filter....it does NOT have the 23.2psi bypass pressure that Subaru calls for. So it wasn't a fib that they did not meet the specifications. The Blue Honeywell filter does however meet the 23.2psi pressure (I measured this myself over 2 filters with 5 totals trials for an average of 23.5psi).
The Tokyo Roki averaged in the high 18psi range. I used a digital scale to get the force that is accurate to the gram so I know that metric is accurate. To dumby check myself, I subtracted .5mm from the diameter of the plunger surface (even though my calipers are accurate to the tenth of a milimeter). Even with that imposed error, the bypass pressure was in the mid 19psi range.
So now the issue is: is it better to have better filtration in a filter that may bypass more frequently, or is it better to have not a great a filtration but has the correct bypass pressure for our high flow oil pumps..
-Dennis
There seems to be some inconsistancies with what is actually in these blue OEM cans....
I found this at
http://forums.nasioc.com/forums/showthread.php?t=1879204
Originally Posted By: 09rexwagon
By09rexwagon
The tokyo roki filter does NOT have the 23.2psi bypass valve. That is why SOA has moved from it. The Honeywell/fram based filter does have a 22-24psi bypass valve. I've tested both. The Tokyo Roki averaged 19.3 psi over my 5 trials. The blue Honeywell has ranged from 21.7psi to 23.5 psi over 10+ trials and 3 different filters.
The Blue honeywell has significantly more pleats than the orange can fram has for the the same spec filter (almost 1.7x more).
So the Catch 22 is this: Tokyo Roki: metal endcaps, arguably better media, silicone adbv but wrong bypass. Honeywell, cardboard media, equal sq in of media to Tokyo Roki, but arguably lesser quality media,
silicone adbv, and the factory spec adbv.
Will the difference in media matter on a 3750 mil OCI......very likely not.
There's a few glaring problems with this guy's observations of the blue Honeywell oil filter compared to the same filter I opened and videoed. There are not more pleats in the blue can vs. orange can and there is not a silicone ADBV; therefore, I'm wondering if Subaru (or Honeywell) has altered the design of the blue OEM filter since this guy opened one. Also, this makes me wonder if the pressure relief valve has also changed. It was at 23psi when this guy tested it (November 2009), but he also claims to of had a different filter element and ADBV than what I just opened up last week. Something is amiss.
Hmmmmmmmmmmmmmm..............
