Originally Posted By: chevrofreak
Running a qt of MMO during the winter time works well. You'll notice a big difference in the cold cranking, and how easier the engine turns over when it gets really cold. It helps!
I think the PP would do just fine in winter all by itself.
Yes, it would. But, the reason I am using MMO is to see if it helps oil consumption. I will use 4 quarts to top off during a 3,000 mile OCI normally.
I did notice a difference already. Usually, if traveling highway speeds and I need to pass (or get out to the way) during heavy acceleration I would see a plume of smoke in the rear view mirror. Yesterday, I saw nothing. It is too soon to tell is it is the MMO or maybe due to a fresh oil change. However, oil consumption is still very high. Just drove 227 miles since the oil change (mostly highway miles) and used 1/2 quart to top off. Around town I usually use half that amount of oil to top off.
