I found an older filter during my aunt's garage clean out. I have compared the 1258 with my Motorcraft FL 1A and it looks to have the same hole and threads and same outer gasket size. It is a bit shorter and has a dome end by pass valve. Does anyone know if it will fit my 90' F150 300 6? I'd only use it for a Auto RX run.
