I'll try and keep this short. I just (a week and a half ago) acquired a 1996 Honda Accord (4-cyl F22B2 non-VTEC engine, 126,000 miles) and it has either just developed or had a knocking sound in the engine. It is a long story but I was unable to listen to or see the car before it was purchased (a gift from an in-law for my daughter). The car has had excellent maintenance on it by the original owner, all scheduled work was done (and documented) and the oil was changed an average of every 3200 miles (conventional Trop-Artic 5W-30). This week I adjusted the valves, replaced the spark plugs and changed the oil to GC and a M1 filter.
Anyway, the noise is pretty loud. It is more noticable when the engine is cold (it sounds diesel-ly, like piston slap) and it does NOT disappear when warm - but it is reduced a lot. I took it into the Honda dealer yesterday for a diagnosis and they said it sounded like piston slap in the #4 cylinder. I tend to agree but the only thing that has got me unsure is that the sound doesn't go away when warmed up. This along with the fact that the previous owner took such good care of the car. Can piston slap happen even with good maintenance and can it still be heard after the car warms up?
I need to make a decision soon. Either we are going back the seller and look for a refund/adjustment or I'm going to live with it. It sounds junky though in the morning, like a car where the owner (now me) never changed the oil. And I hate being seen in a car like that.
When I adjusted the valves the engine looked VERY clean inside. Some varnish but no deposits whatsoever. It doesn't appear to use any oil and the compression test I did came out 189, 184, 185 and 190 - well within the Honda specs. I just can't believe it is something due to poor maintenance.
I've been poking around on it for three days using a stethoscope and I can't pinpoint the source of the noise. I'm pretty much with the dealer's diagnosis that it is coming from the block, and specifically the #4 cylinder.
Any advice is appreciated
