Modern-Day Synthetic mono-grades pour and flow at extreme temperatures at least as good as any Dino mono or multi grade out there.quote:
Originally posted by kickster:
Since synthetic has such a low pour point then why not use a single grade oil that contains no VI!
Dont you the engine would run, cleaner, better with less VI? 30 weight oil should do the job of 5-W40 dino oil!
Interesting, the VI numbers look like they are actual straight weight oils.quote:
Originally posted by AstroVic:
Royal Purple has SAE 30, SAE 40, and SAE 50.
http://www.royalpurple.com/prodsa/rpmoa.html
Mobil 1 V-Twin 20W-50 contains no VI.quote:
All recent(last 5 years or so) marine engines marinized by Volvo Penta are required to use a straight 30 synth for warranty.quote:
Originally posted by Ugly3:
Because there is no place in the market for straight weight synthetic oils.
If it has no VI improvers and still has suitable cold temperature properties it will meet one of the winter viscosity ratings and then be appropriately labelled as such so that people will buy it.quote:
Ugly3 was probably referring to the automotive oil market!quote:
Not per se.quote:
So, I'm a bit confused.
Is there any advantage whatsoever to using an SAE 30 over a 10W30 (for example)?
For Houston area, most of the time thicker oils do nicely. Castrol GTX 20w-50, or even better, Castrol HD-30. You will not need 5w-30 or 10w-30 in such a torrid, sweltering environment, except for the very rare cold Winter. Even then, it is thin oil in by December, out by end- February.quote:
I live in Houston, where it seldom gets anywhere close to the freezing point. I've always used the 5W30 or 10W30......
(abbreviated)
Um, could you please state that in layman's terms?quote:
Tribo-chemically speaking,...
