I am looking for a very large oil filter to fit on my Buick 3.8 liter V8 powered 914. Space is not an issue near the filter mount. I have the smallish 18mm X 1.5 mm threads on the mount.
I am looking at a longer (it is about 5 inches long) filter such as the WIX 51036, however that filter is still the same diameter as the one I want to upgrade from.
Is there a much larger filter available that will fit the 18 mm threads? I can go a lot fatter and even a bit longer than the 51036. I can fit a BIG can there, as Big as the Fram HP1, if it had the correct threads, and gasket.
P.S. The filter gasket is about 2 5/8 inch diameter.
Thank You
Thank You
