Originally Posted By: bigj_16
Originally Posted By: btanchors
Originally Posted By: Speak2Mountain
He's right. Lighter oils typically have problems in GDI w/fuel dilution and have a higher NOACK
Which property would be more predictive of resistance to LSPI - a higher flashpoint, or a lower NOACK? The reason I ask - Mobil won't say what the NOACK is of Mobil 1 Annual Protection 0W-20, but I note it has an unusually high Flashpoint - 242 degrees C, which equates to 467.6 degrees F. Isn't that unusually high for a Flashpoint for a PCMO in 0W-20 weight?
I am no expert on LSPI(apparently no one else is either
). But I have never seen NOACK or flashpoint mentioned in any of the LSPI studies I have read. For the oil itself, I have seen mentioned:
A higher viscosity is better
Groups V, II, III, IV are better to worse, in the order given.
Calcium is not good(particularly above 1500 ppm)
Magnesium is neutral
Molybdenum(especially), and zinc can negate the calcium
This is all very preliminary. The engine design, amount of miles, type of gasoline, operating conditions, operating rpm, and other things also are factors.
And GrpII might even be better at resisting IVD build-up...
