My Dad's Cub Cadet Tractor has 25 hours on it so he said can you change the oil and filter, I said no problem, so I drained the oil, no problem, go too take the oil filter off with the strap type oil filter wrench, problem, will not move and the oil filter is starting to crumble, I better get this thing off or else I could be disinhereted, I try again and oil is starting to come out and it is barely moving, so I said maybe I need to try the screwdriver trick, I found a small one and stuck it through and with both hands I turned it with everything I had and it slowly, I mean slowly started to turn and I got it off.This oil filter from the factory was only on there 25 hours, I am thinking that they either did not oil the gasket or Superman down at the Kohler assembly line put it on, I am going to get him a cap style oil filter wrench tommorow. Do you guys have any ideas why this happened or has anyone else had this happen. I was soaking wet with sweat after everything was said and done, if I ever by a piece of lawn equipment brand new that has a Kohler Engine and oil filter the 1st thing I am going to do is take it off and put on a Mobil 1 Oil filter, Wix, or an Amsoil EaO Oil Filter, I would not want anyone on this board to go through the experience I had today.
