Originally Posted By: IndyIan
It's not a bad engineering solution though, just take the grip away from the tire that going to cause the rollover. It's already dodged the moose, so what's a few more feet before you get back into your lane.
My impression from the article was that the behaviour was unacceptable because it would either put you in the rhubarb on the other side of the road or straight into oncoming traffic.
The GC just has too soft shocks, so it transfers its high mass unhindered to the other side and bounces like a kid on a trampoline.
Which has me curious as to which one they tested, as the R/T has adjustable suspension and in sport mode has significantly firmer damping. Would that change the behaviour?
I'm sure yours has more grip and is much closer to rollover in a steady state turn than a normal GC even with its lowering, but in the moose test the mass of the body is damped by the shocks and less likely to overturn than a normal GC.
You are likely correct, however I still find the test results interesting and would really like to see what a chassis sibling Mercedes looks like in the same test.
Can you imagine a 90's Explorer or Jimmy/Blazer doing this? LOL!!! What about a Suzuki Samurai?
Yeah, alot of the old body on frame SUV with semi off road capable suspension wouldn't do well! If you put on some much stiffer shocks and left the springs alone, I'd think the GC in the moose test would do much better.
GM was pretty serious with trying to keep my 03 Tracker right side up, with very stiff front springs and struts, a good size front sway bar, soft rear springs and no rear sway bar and 26 psi tires... Also the front brakes probably did 90% of the stopping.
Closest I came to a moose test was avoiding a skunk, but I didn't feel the need to sling the car quite that violently and the back end stayed quite stuck and I ended up hitting the skunk... On a gravel road you could get it sideways by flicking it, but you had to try.
Anyways, I don't think the front ride quality from this setup would be acceptable in a GC, but it worked without any electronics. The CRV in comparison is a little scary how easily it will rotate on gravel, but the stability control system is quite effective.
