Hi,
My Holden Rodeo Gearbox and Transfer Case call for the same oil as the engine, or SAE 5W-30. I'm using 15W-40 in the engine.
If I use Penrite Tractor Transmission Oil, SAE 10W-30/75W-80, would I see any bad effects?
At least it's an oil designed for gearboxes, and still meets SAE 10W-30. It also meets API GL4. The cold viscosity isn't really important, as temps here never go below 1oC.
It currently has Caltex Easy Shift 75W-90, but the gearbox feels very heavy when warm.
