Originally Posted by Patman
Originally Posted by oil_film_movies
... GM
engineers must think the Silverado can limit oil temperature better than a Corvette. Going up a 7% grade towing a big boat or something would stress the Hades out of a Silverado engine running 0w20,
you'd think, but
oil cooling might be very effective in a Silverado, and
its really all about temperature.
The ~240F oil temperature is a piece of cake for any full syn oil 0w20. Ford once had a chart on oil ageing stress vs. temperature, and their ideal for
conventional Group II oil was 210F (see below). So 245F in a Silverado with dexos1 0w20, according to GM engineers, isn't enough to thin the oil down too far and/or age it too much.
Taking GM engineers word for it, and then allowing yourself a 10% HTHS safety margin would result in using an xw30 HTHS 3.0 oil. M1 5w30 ESP and T6 Multi-Vehicle is about a 25% margin, more than needed above spec.
https://etda.libraries.psu.edu/files/final_submissions/392
The funny thing is, I really don't see 240 degree oil temps in my Corvette at all, although I definitely would if I were racing it. For most of my driving, my oil temp stays in the 185-195 degree range. It only goes above that if I make a bunch of full throttle runs in a row or get stuck in traffic. But even then I don't think I've seen it go above 220 very often.
What's even more strange is the fact gm engineer's used a 194 degree thermostat in your Corvette and a 206 degree in the truck, I have removed the 206 and replaced it with the 194, actually I just bought the complete water neck and thermostat housing from a Camaro and Corvette as they are a direct replacement . Funny how similar the engines are but yet call for a 0w20 . CAFE.....?
