Originally Posted By: supton
Something I'd watch out for, is that if the temperature shown does not change "fast" then it might be pan temperature. Meaning the oil will see much higher temps coming out of the convertor. 180 in the pan might be 250 (momentary!) before headed to the convertor.
Yeah, my numbers are based on transmission sump temperature. That gives you ~50F of buffer for a unlocked converter pulling up a hill or whatever.
210-250, 250-270, 300+ would be ranges I would expect on the cooler out line for the same ranges I posted earlier.
And I think you meant headed from the converter to the cooler.
