Originally Posted by MGF1964
Not bad as a cleaner (it's nearly half solvent in terms of composition), average at best as a lubricant, a bit on the lacking side as a long-term protectant.
There are better CLP products. That said, if you clean and inspect regularly, it should get the job done.
This.
As a cleaner it is pretty good, but as a lube it isn't. Once all the solvent evaporates very little oil is left behind, and that oil isn't that great as a lubricant or protectant.
I still use rem-oil as a cleaner, but follow it up with a different lube. Lots of good ones out there.
