Originally Posted By: Gokhan
The reason for the TEOST exemption was that the Japanese manufacturers wanted to load their 0W-20's with many hundreds of ppms of moly and did so in the past (ADEKA SAKURA-LUBE), which leads to deposits.
Read through that a couple of times, and don't see where it mentions hundreds of PPM of moly, or increased deposits, leading to lobbying the API to change the results for 0W20 only...why just 0W20, and not the Japanese other offerings in other viscosities.
It has nothing to do with the base oil or viscosity. Today newer forms of moly such as the Infineum trinuclear moly work at only 75 - 100 ppm in achieving the same friction modification.
But the thinner base oils should have kept these cleaner...
Regarding MoDTC…here's a Savant group paper on it. 360ppm of Mo ion. including TEOST tests with and without the moly.
https://www.savantgroup.com/media/2005-P...e-Oils-STLE.pdf
