StevieC Joined Aug 21, 2008 Messages 25,104 Location ON, Canada eh? Nov 11, 2017 #1 Music is annoying - Be warned.
FowVay Joined Jun 2, 2002 Messages 4,204 Nov 11, 2017 #2 I found the music to be quite pleasing and the technical innovations to be genius!
skyactiv Joined Mar 2, 2013 Messages 11,903 Location The Midwest Nov 11, 2017 #3 Actually, the pad lock on the brake rotor on the motorcycle isn't a bad idea.
Z ZZman Joined Mar 17, 2008 Messages 8,374 Location Michigan Nov 11, 2017 #4 I actually saw a guy at AutoZone that tried to fix sidewall leaks in his tires with bolts and washers and green slime
Cujet Joined Feb 15, 2003 Messages 15,690 Location Jupiter, Florida Nov 13, 2017 #5 At the end, there are mufflers with turbos. That's a great way to completely hide a turbocharger setup.
SuperSalad Joined Feb 3, 2016 Messages 1,330 Location NJ, USA Nov 13, 2017 #6 Originally Posted By: skyactiv Actually, the pad lock on the brake rotor on the motorcycle isn't a bad idea. It's my preferred method But I feed it through the holes in the rotor, not over the entire rotor, makes it nearly impossible to cut in any timely manner.
