I want to point out that Bob's motorrized machine is almost identical tot he display units at Autozone pitching Luccas. The only difference is tht a motor is spining the gears instead of a hand crank. I also want to point out that this machine would cost you a lot more then $20 to build. Electric motors are not cheap! I belive we have some not so great UOA on this site some place of motor oil with Lucas in it. I use their their Fuel Treatment and have used Lucas in manualy transmission when the wearings were going south to extend their life but would not put it in anything that was in proper working order.
Oh, I forgot to mention the ratio thing. Lucas claims their product will climb the gears at 20% ratio. In order to get the proper ratio he added until the product performed as claimed by manufacturer. So by defualt either the ration was close to 20% or Lucas is not accurate with their product claims. When was the last time you had a customer compute the exact amount of Lucas he need to add to arive at 20%? DOes the staff at Autozone do this for them ? How many UOA have you done on your vechiles useing Lucas?
