Originally Posted By: 4WD
This combined with a stop watch would be better, cheaper, and use actual (recorded) seconds to move 1 quart …
(Database or spreadsheet)
Or if cold pumping really matters ~ run 0w and check the MRV of that product …
That a paint viscosity funnel?
Snag is he's running a comparative test.
To do that with this kit, you'd either have to buy a lot of them and put them in his rig (which will be quite a lot more expensive and perhaps only slightly better from a manufacturing tolerance point of view) or you'll have to run a whole test series, at -20C outside (assuming this uncontrolled temperature is maintained constant, which is unlikely) cleaning the kit between runs.
This will give you major variable control problems
And frostbite.
And maybe sleep deprivation psychosis and marital breakdown.
I don't think you've thought this through.
I reckon his rigs not bad, (though I think I could put something better and cheaper together) but I'm not sure that the result tells you anything very useful.
To be fair he doesn't make any big claims for significance, just presents the results for interest, so that's fair enough.
And frostbite.
