Originally Posted By: mrsilv04
I cleaned out my local W*M of all the the old stock ST10955 for the Town and Country. The old stock is sourced from Wix and is marked as 'Made in the USA' (with 25% or less foreign content). They had them at $1.50 each.
The new stock does not have the Wix design free floating bypass valve, and is clearly marked as Made in China. To the naked eye, there was little difference in the media, the number of pleats, or the construction.
I'm a bit disappointed to see that the Pennzoil Gold Synthetic Blend has also exited the building. I've used it exclusively in the T&C and the Sierra since W*M started carrying it.
I guess the next best nearest SOPUS option is going to be QS SynBlend High Mileage.... or I could go cheap and go to Harvest King 5w30 Synthetic Blend on both. I'll probably just start buying the Harvest King by the case and use it in everything.
Make your own synblend for the same money. That way you can blend 50% mix, instead of the 25-33% synthetic the bottler puts in.
Just need to buy an extra jug to begin with - then have leftovers.
