Originally Posted By: Mossyoakglock
I was comparing Pennzoil PP 5W-30 and 10W-30 and noticed that the 10W has lower MRV numbers. Is that common for a thicker oil to have a lower number than a thinner one?
I might be way off but I'm still learning what everything means when it comes to oil and specs. The lower the CCS and MRV numbers, the better/easier it flows when cold?
Sorry, but this is still a positive displacement pump. SO as long as the oil is liquid (vs freezing - gellation), it's all going to pump at the same speed. There is no faster to the top, or anywhere else involving the pump ...
Sling and splash oil will be a bit different. But not a whole lot either.
Yes, a filter can make a difference in that the anti-drain-back-valve does not seal as well. Silicon rubber valves are the best, so that's Napa Gold (WIX), Fram Ultra, Baldwin, etc. If you get cold start lifter tick, that's the first check, swap in another filter with known good ADBV.
Next is a can of BG109 or KREEN for 100 miles before the next oil change. If that fixes it, it was a tad of varnish build-up in the lifter. If not, it's something else.
I'd run spec oil, or if veering off spec, I'd go 0W-30 and see if that helps ...
