Warning: The following message is rated "E" for everyone and contains graphic content of a tear free Pureone. The following photographs may be dangerous to those with a weak disposition and/or those suffering from chronic Framophilia. Do not attempt this at home unless you possess a BITOG Professional Filter Cutting Certificate.
This is a PL14670 removed from the truck in my description after a 3000 mile (+/-) OCI (changed out early due to severe service off road.)
No tears, no cuts, no rips and the metal end caps were securely glued in place. The media was a tad wavy in some spots, but that is only cosmetic. The can was intact and the anti drain back valve was extremely pliable.
It did an OUTSTANDING job filtering out quite a bit of fine contaminants that were left over in the remaining oil inside the can and some that were left in the pleats (it isn't a sludger, I just ran a can of 5 minute motor flush to really clean it out.)
Feel free to browse and I will answer any questions you may have.
I dont have that chart memorized, so if someone could decode this it would be much appreciated! Enjoy!
