I use a PH3985 on my Honda Odyssey -- it's the largest 20x1.5mm thread filter I could find. Bypass setting is very similar. It has about a 1/4" larger gasket diameter, so the mounting base has to accept it, plus you need the room as it's substantially larger than both the PH7317 and PH3593A. The PH3593A is a bit wider than the PH7317, but it's not a huge difference in size. The PH3985 is a monster compared to them. There is ample room on my Odyssey, but on my Nissan Maxima which also accepts PH7317/PH3593A, there's no hope as the filter contacts the oil pan before it will seat all the way.
FWIW, the PH3985 was used on older (80's?) AMC vehicles. Jeeps, old-school Eagles, that stuff.
