Originally Posted By: ccap41
Originally Posted By: philipp10
Originally Posted By: dlundblad
I asked this before, but didnt get a straight answer.
Whats the point of running a thicker running weight in extreme heat? We see here that (some) Australians and folks in the Middle East like a 50 or 60 weight oil. Wouldn't the radiator keep oil temperature somewhat in check and prevent any oil related failures? I would also think an oil cooler would be a standard option for vehicles in these regions. We also see engines that spec a much thicker weight in Europe and the other mentioned regions while the identical US version will take a 20 or 30 weight oil. (It has been mentioned here that a European car's severe use yields a thicker oil.. high autobahn speeds for example?)
I don't understand the reason behind any of this. In the US, thin seems to be in while other places are still using a thicker oil.
I think his question is, since all cars have a cooling system, then other than during warm up, why spec different oils? In effect, a car in Minnesota in winter and a car in Florida in summer, after warm-up should both see the same oil temperature, so why spec a diffent oil.
My answer is, warm-up is a killer of engines. That's when most wear occurs. however, if you are in a warm climate, might as well spec a heavier oil to take advantage of the fact you can.
From my readings you are spot on. The warm up process is what harms the engine more than anything else(lubrication-wise). Starting thinner helps things flow at much cooler temperatures and there are a lot of drivers who only make 10 minute trips meaning things are even up to temp when you're already parking. That is one reason I run a thinner oil than spec. I make a lot of 5 mile and under trips and with a thinner oil it is at least flowing the way my vehicle needs when I shut it down, even if it isn't all the way warmed up yet.
It isn't the flow of the lubricant that effects wear during warm-up. The oil is pumping and flowing just fine if it is 0w-20 or 5w-50 assuming it isn't -40C out. The issue has several components to it:
- Fit of components when cold is different than when warm. Pistons are looser in their bores. This is one reason some engines have piston slap.
- Fit of rings on cylinder walls is poorer partially due to the first point, which results in blow by gasses going pasting the rings into the crankcase
- Fuel wash on the cylinder walls from the enrichment cycle and cooler cylinder temps. This washes the lubrication from the walls as well.
- Additive heat activation temperature. This is a huge contributor. The additive package in the lubricant, certain components require heat to activate. Member bobbydevro posted on this (as did Shannow) quite recently actually.
This is why we have start-up wear. Once the engine is up to temp; once the additives are activated, parts fit properly, blow-by is reduced, fuel and moisture are flashed off....etc. Then wear becomes as close to zero as it can get.
Thank you, very good information.
