901Memphis said:The engine builders agreed on 5W20 in the OPs application, and back it up with a warranty, and billions of miles logged. Unless the OP plans on modifying the engine or drag racing I'd stick with 5W20.
If that's the case, why are we here? If the people can just look on the oil fill cap to get the recommended viscosity, why are we here? Maybe we should all go home right now and mind our own business.
I am home. My suggestion is if you know better than Ford send them a resume. A great company, cutting edge too. If they felt 5W30, 5W40, or a 50 grade oil was best they'd suggest it. 5W20 isn't the only oil Ford recommends, their Turbo engines, Diesel engines, and engines in the HP Cobra all use something other than a 20 grade, so they could have easily suggested another grade of oil. If they felt the OPs engine would be better suited with a thicker oil they would have recommended it.
I've discussed this at length in PM land with Johnny a retired Pennzoil employee. Who is very familiar with the testing of 20 grade oils in both Ford and Honda applications. Doug Hillary and I have chatted about it too. If you read any of Doug's threads he'll say "use what the mfg suggests" as well. Doug knows more about oil and lubrication than anyone on this board, so what he writes means a lot to me. All I can tell you is the 20 grade oils have been extensively tested and work well in applications "calling for it". Believe what you want. The OP's car will do just fine running with it in the sump.
