Let's for the moment consider that all filtration media is basically the same except for micron level. Now we surely have advanced medias ..but I think that they're not necessarily anything special outside of how they provide better filtration ..at least that's how I'm looking at them in this pondering.
Much depends on the holding capacity. A looser filter can have a LONGER life in the same service as a finer filter. This is limited to the media's longevity. The service duty has a lot to do with it.
If you're using a cheaper filter (assumed lower level of filtration) in the same service as a finer filtering filter in long life service, then there is a good possibility that the cheaper filter can last longer. Now the nitrile ADBV may be dysfunctional from a consumer standpoint ..but
You'll just have much higher particle counts circulating around.
So, if you're doing 8k a year (assuming daily driver use)...more fuel, more moisture, higher combustion byproduct levels ..etc...swap out both at 6 months (oil and filter) or sooner.. and go as cheap as you please.
If you're doing 16k a year ..less fuel ..less moisture..lower combustion byproduct levels ..etc...swap the oil out at 6months and the filter at one year and go as expensive as you please.
This is generically speaking. There will be more and less severe situations and oils and filters that can got further distances due to unique construction.
Under the same service, generally speaking, any filter will make 10k. I'd say that under ideal (highway) conditions, all filters could reach 15k from a loading standpoint. The difference being the level of filtration. The ADBV will probably fail to be 100% effective if it's nitrile, but that isn't a typical OEM requirement. The ADBV typically has a time spec for holding. Otherwise, most of your filters are not "meeting or exceeding OEM spec's".
