I wouldn't. There is NOTHING wrong with the FL-820S.That depends if that engine calls for the infamous "820S". If that's the case, I'd skip the Motorcraft.
John Q. Public brings his 2019 Ford Fusion to the Ford dealership for a rod knocking sound. The service manager asks to see his OCI records and receipts. He asks Mr. Public why he is not changing his oil filter at every OCI? Mr. Public tells him that a member at an oil website states that Honda recommends to change the oil filter at every other OCI. Member X there states that if Honda says it's okay then l should be okay doing it as well.
So, Ford does an investigation and finds the oil filter to be loaded up to the point that it caused damage to the bearings. Will member X at that oil website pay for your new engine being Ford won't?
Sure, it sounds far fetched. But, just because Honda recommends it, and you drive a Ford, ..........well, you get the point.
You mean besides the torn ones repeatedly documented here on Bitog and elsewhere:I wouldn't. There is NOTHING wrong with the FL-820S.
NOTHING is wrong with them.You mean besides the torn ones repeatedly documented here on Bitog and elsewhere:
Guess it all has to do with the meaning of “NOTHING” being wrong with them.Fl820s fail - Ford Truck Enthusiasts Forums
Oil & Lubrication - Fl820s fail - I bought my 2008 F350 may of last year and changed the oil soon after I got it. Used a Motorcraft FL820s. Only use the truck to tow the camper and haul thing home from Lowes and stuff like that. Only put 2500 miles on the oil and filter. Just changed the oil...www.ford-trucks.com
He should have bought a Honda, right? Then he can run the filter 2+ times.Loaded up? Never seen such a thing on a well-maintained engine. Your example seems highly unlikely. Outside of a warranty claim, running an oil filter longer than the manu recommends seems like a non-issue.
Is Fords interval even one year for his model? It’s likely written as 3 months. Oh, man, he’s in deep doodoo now!
THAT'S A SIN!Yea, and that double interval would STILL be half of the Honda’s single interval.
I get your point, though. OP, BlueOvalFilter and I agree that you should run your filters for FOUR OCI’s!
Leaving a filter on a cast iron block “for years and years” can cause issues? First time ever reading this.
Thats a fun car.
As long as there is no rust anywhere on it Id leave it on for 2 years.
9 times out of ten a seized filter is caused by over tightening .I tried to remove an oil filter from a 3800 and it was practically seized! Even a hammer and screwdriver couldn't get it off! I was able to eventually remove it, but boy was that thing on there! It is possible that the gasket wasn't oiled.
Even similarly overtightened filters on other cars came off with a hammer and screwdriver.
