I cut mine apart, look at them, drain the oil in the used oil container, and chuck the rest in the trash.
Thank You. I didn’t want to spell everything out. Guess he didn’t understand a word I posted. If I’m lazy I will take my incrished used filters to work and crush them. End of story, plain, Jane simple.,You may want to take some time doing a search for for profit oil filter recycling operations. There are a number of them in the country that have found it quite profitable. One operation in particular recovers the metal and oil. It is actually surprising how much oil they are able to recover. All the other material is incinerated. The incinerator process leaves only the metal, adding to it's value for recycling.
I have zero idea that’s 0 idea how your town/city will process the used filter parts. Basically I don’t care. My village has agreement with local recycling place at my park. Everyone’s town is gonna be different. That’s 110% factI'm good thanks, how does my used filter that I drop into my recycle bin find its way to them? That would mean that my local city employees pick the filters out by hand and put them into a bin that goes to the element separating wizards?
I took an old motorcycle battery to batteries plus a couple of years ago and they said they charge a fee now to take old batteries. IIRC I took it to AZ.Home Depot takes batteries and I think a " Batteries Plus " store
This!... Everyone’s town is gonna be different.
Very good DNewton3. I didn’t realize your situation.This!
I don't recycle my filters after I cut them open. I care mostly about the oil; I want it as drained as possible. Perhaps that's because I've lived on well water and don't want my ground water polluted.
Past that, though, the rest goes in the trash. Mainly because my trash service does not participate in recycling. I called them once and asked if I voluntarily separated the glass/plastic/aluminum/etc would they take it for the purpose of recycling? Nope - all goes in the same truck and ends up in the same landfill. The closet recycle center is way far away from me; one could argue that the gas burned to get there and back offsets the other purpose of being "green" in recycle efforts ...
The used oil filter recycle operations I was referring to, are those that collect filters in bulk, from places like lube shops, dealerships, indy shops, dedicated recycle facilities, and such.
The county dump here has a place for oil filters, right near the used oil collection tank.
EDIT: They also take tires, up to 4 per day per resident, for free.
"...dump my antifreeze in the toilet...."
pretty bad for the town/city treatment plant / ur septic system & the rest of the environment.
Increases costs if city/suburban dweller.
Kills the microbiome that goes to wrk on the chit'n rest of it in these systems...
The Missouri Department of Natural Resources encourages the prudent recycling of all waste antifreeze. However, if a batch of waste antifreeze is nonhazardous, it may be solidified to the point that no free liquids remain, and the wastes may then be disposed of at a sanitary landfill.
Also, if the facility is connected to a sanitary sewer that discharges to a Publicly Owned Treatment Works (POTW) and the wastes will mix with domestic sewage, the waste antifreeze may be disposed in the sanitary sewer on-site. Before such disposal, the POTW must be contacted to verify they allow waste antifreeze in their system. You must obtain permission and retain documented permission to discharge to the POTW. Waste antifreeze may never be discharged to storm sewers, septic systems, streams or be dumped on the ground.
not all the chem in there by each 'bug'.
Did they evolve in that enviornment?
My bet? U didn't either so having it in our water (soil, ground) is not healthful for us never mind the the cost to replace 'them'.
