- Joined
- May 24, 2023
- Messages
- 41
So...after completely rebuilding a '96 4L60E for son's '69 C10
(see this thread for details: https://bobistheoilguy.com/forums/threads/another-4l60e-build-with-questions.371065/
and the clearances / specs are pictured below.)
Last weekend we pulled out the tired 700R4 and swapped in the new trans. Hooked up a USShift Quick4 controller with a stock (5000rpm shift) tune. Checked line pressure, 60 at idle in D, 75 in R. Pressures ramped up dramatically with the throttle, and followed the pressures indicated in the Quick4 - so we concluded the Quick4 was indicating correct line pressures.
Let the engine and trans idle to warm up (engine 180, trans 170), doublechecked the fluid level, Went for an easy test drive, and all seemed well for the first 4 miles - all gears shifted well, nothing seemed slipping, no obvious issues - until I looked down and saw the the trans temp at 210, 215, 220...we pulled over, let it idle in P, checked the fluid level, checked no leaks, etc. It cooled down to 210, so we started easing it back to the shop - and the temps climbed, seemingly no matter which gear we held it in. By the time we got to the shop it was well over 260.
We doublechecked the line pressures, all was in spec, checked the fluid - it wasn't discolored at all, no debris in it, but it smelled like a burned pizza.
Let is cool down while we ate supper, gave it some thought, and wondered if the line pressure curve wasn't steep enough - because the Holley Sniper EFT is set up to use all 4 bores simultaneously, which means the truck drives down the road at 60mph with around 10% TPS, and so maybe there wasn't enough pressure to keep the clutches held while going even 30mph? Surely stock pressures are enough - otherwise I can't be the first to kill a transmission with this setup...?
After it had cooled down below 90F, I raised the static line pressures by about 50psi across the board, and raised the shift firmnesses as well. Went for another test drive, and all seemed well, temps never got above 180F, except the shifts weren't as hard as I'd expect (I'm not sure what to expect, they just didn't seem...)
Knowing that the trans was hurt, I pulled the pan and found tiny black flakes, and both magnets were fuzzy with black debris. No shiny bronze, aluminum, or other non-magnetic debris, looks like just friction and steel materials.
Pulled the filter (which looks good) hooked up a hose from the pump inlet to a jug of new fluid, started the engine and let it push new fluid through the trans and into a large catch pan, then replaced the filter and fluid.
Went for another short drive, and temps never got above 180, all gears work fine except 3rd, which slips badly. Dammit.
Ideas about where we went wrong, other than not maxing the line pressure at the first sign of trouble?
Trans is obviously coming back out, what's the fix?
