OVERKILL
$100 Site Donor 2021
Originally Posted by yowps3
I wonder why Europeans recommend 40 wts while American and Japanese are recommending thinner and thinner grades.
Especially on today's motors that are ultra hard on oil
My SRT calls for a 0w-40, as does the Corvette now. You'll find that most Hi-Po mills call for heavier oils and 0w-40, with its wide spread, is probably the most common flavour. This aligns with the expectation that these applications will encounter situations where oil temperatures are elevated (track days for example) and the additional protection is needed. This runs contrary to the expectations for most "appliance" applications where runs to Walmart and the Beer Store or loafing down the highway are not going to elevate oil temperatures. These are also the bulk of sales, so tiny incremental gains in fuel economy realized through the spec'ing of lighter oils have a cumulative effect on CAFE credits.
To ensure that the lighter oils will work suitably in these applications you'll typically find one or more safety mechanisms in place designed to keep oil temperature within an appropriate range and, if that cannot be done, reduce output:
- Oil coolers
- Increased sump size
- Finned oil pans
- Thermal castration mechanisms (PCM pulls power when oil temperature hits a threshold)
- Oil coolers
- Finned oil pans
