Originally Posted By: fenixguy
Originally Posted By: ARCOgraphite
WORST: OEM NISSAN Made in China. Absolute Garbage engine destroyers
How many documented cases can you share of said filter causing an engine failure? Curious since I own a Nissan; I might want to avoid these. I believe the one on there now was made in Mexico.
Sorry not a data collector but an Engineer with 30 years experience and Master Mechanic with 7 years. Nissan China Filter didn't work on two different Nissans - A Rogue and a Versa Note. Tried another brand, engine immediately runs fine, evidencing no knock or VT racket - put the CHINA filter back on, engine mechanically knocks.
Just look at the picture below - it cant work. No room for oil flow into the filter!
I wouldn't think you could get a China filter now at a dealer, or it may be old stock. You can Read online about mysterious ruining of thousands of versa engines including MINE And A couple guys on here, I don't recall their used ID. There is a TSB on Nissan engine noise - before they figured out it was the filter.
Run a Champion(Mobil1 filter) or a FRAM
Toughguard.
Toughguards are OEM spec HONDA and Subaru in the USofA. Just painted BLUE
Cant be that bad. Or FRAM works in this application - not EVERY application.
NOt a GONHER fan either. Went thouirgh a few of those and had ADBV failures - Flap softened and remained OPEN when it should be closed. Appear to be a material incompatibility issue.
