Originally Posted By: JTK
I believe the "new" Ariens 21" mowers are built by the Husqvarna Group. I'm not saying this is a bad thing, it's just not the same Ariens you might be used to.
Like said above, a Toro Super Recycler is a fine bagger, with the Snapper Hi-Vac being even better. Hondas are decent baggers as well.
I'd rather have a root canal than bag. Mulching or side discharge all the way for me. Best readily available, and reasonably priced mulcher is a Toro Super Recycler (HAS to say "Super").
My Toro Super Recycler was a horrible bagger. Wouldn't hardly inflate the grass bag with air only. Tried OEM Toro blades and Gator blades. Not even in the same league as the Snapper Hi Vac. Especially when you bolt the air lift kit (wings) to the Snapper blade. Will suck coins off your garage floor. Leaves and grass no problem 6" away from the deck. Hands down Snapper Hi Vac for bagging.
Every other mower be it Honda, Husky, Ariens, Toro or insert the name here, not even close to a Hi Vac Snapper.
slomo
