Mobil1 0W-40, 5,140 mi, '04 Forester XT Stage I
NJ
UOA by Oil Analyzers Inc. Previous uoa here.
Driving conditions: Oil in use January - August 2012. This is my first full uoa after installing a Cobb Accessport and I am running the standard "Off The Shelf" tune which explains the increase (?) in fuel. Previously noted fuel levels were estimates, and this one was done by GC. Estimated hp/tq on the Accessport for my year Forester XT is 270/285.
7 mile daily commute each way; spirited driving with a few redlines here and there on days where I have a 20 minute drive. Longer trips on weekends as well as driving on the beach. I ran the oil for about another 1,000 miles after this uoa and the factory recommended interval is 3,750 miles. 1/2 quart make-up oil added at 1,860 miles into oci and one quart at 3,220 miles into oci (after trip to SC that included more enthusiastic driving
Lab comments: Data indicates no abnormal findings. Resample at normal interval
Equipment make: Subaru
Equipment model: 2.5L Turbo
Oil use interval: 5140 miles
Oil type & Grade: Mobil1 0W-40
Make-up oil added: 1.5 Quarts
Miles on unit: 122,140
Air filter: Amsoil Ea panel filter
Oil filter: OEM Honeywell
Overall severity of report = 0 Normal
Code:
(newest to oldest, left to right)
M1 0W-40 SN; X-Lite, PU 5W40, M1 0W40 SM, SSO; SSO;
Iron 16 4 8 7 11 11
Chromium 2 0 0 0 0 0
Nickel 0 0 0 0 0 0
Aluminum 4 0 2 0 3 3
Copper 9 8 8 15 5 6
Lead 3 1 1 0 10 4
Tin 0 0 0 0 1 0
Cadmium 0 0 0 0 1 0
Silver 0 0 0 0 0 0
Vanadium 0 0 0 0 0
Silicon 8 7 7 8 10 11
Sodium 8 2 10 22 28 90
Potassium 3 0 0 3 2 2
Titanium 0 0 0 0 0 0
Molybdenum 101 4 24 123 2 1
Antimony 0 0 1 2 0 0
Manganese 0 0 0 0 4 0
Lithium 0 0 0 0 3 0
Boron 139 6 117 112 7 7
Magnesium 17 13 19 30 17 17
Calcium 3273 3323 2347 2805 3497 3423
Barium 0 0 0 0 0 0
Phosphorus 946 984 824 880 654 677
Zinc 1135 1145 1050 1061 717 755
Lube chg No
Filter chg No
Fuel % .8 (GC)
Soot
Water
Vis @ 100C: 13.2 11.3 12.1 13.2 10.1 9.6
TBN 5.06 4.93 3.78 1.99 4.35 4.01
Oxidation 28 47 15 37 43 38
Nitration 16 26 27 27 32 27
If I didn't get Motul for free with my Subaru cc rewards, I would probably stick with this oil. Actually, probably not since I change my mind once a week.
-Dennis
-Dennis
You sound like me.
The OTS tunes do tend to be a bit rich.
Do you have an aos on your fozzy?
-Dennis
You sound like me.
No AOS. I've considered it because of the consumption, but figured my consumption isn't really as bad as some. I even have my stock catted up-pipe and some would say I'm playing Russian Roulette.
-Dennis
-Dennis
You sound like me.
-Dennis
I've been very happy with my Crawford V2 setup, cut my consumption to virtually zero. I used to be able to burn oil at will with the skinny pedal.
I don't think too many people here will give you a hard time about the UP cat, just don't admit that over on the blue and yellow forum without yer flame suit on.
You plan to show us a UOA on that 300v? I'd like to see that.
The head tech at my dealer told me he has seen only two cases of grenading uppipe cats. I'm planning to do a voa and uoa on the 300V.
-Dennis
M1 0w-40 burned a little more also when I tried it for 2 runs before M1 HM 10w-40. 1.5 quart per 5k / 7 months is a little bit high for my taste, but it's probably not a big deal.
Why do you think your TBN is much stronger this time, than the last time you used this oil?
My OCI on the run of the SM oil was 6,034 miles. I don't recall the starting TBN but you can probably find it with a search.
-Dennis
The present figures look fine, but which oil were you using when you got the 10 figure for Lead. It was low on Zinc, Boron and Moly in terms of anti wear additives. You have it labelled as SSO, when it looks more like an SOS in wear metal terms.
That was Amsoil Signature Series 0W-30 and the last time that I ran the interval that long and the last time I used an oil with an HTHS of
-Dennis
