Originally Posted By: Garak
You're still chasing something that doesn't amount to squat in the real world,
nor translate to real wear. If you're chasing a few PPM of iron to base your oil choice, it's not doing you any real good.
If it's not real wear, then what is it, Garak? If 27ppm isn't bad/real then why is 150 ppm? Someone special, that I've been told about, deemed that number to be bad
IIRC, that person also recommended not to use that oil anymore and look further into possible engine problems.
If the OP continually seen higher than average wear numbers, UOA after UOA using Mobil oils, at what point, if one were to add all those numbers up, would one decide to quit using it? I never did UOAs when I used Mobil oil, I just seen numerous on here that showed high wear metals, UOA after UOA, and that was enough for me, which I am thankful for and this site.
Originally Posted By: PimTac
“Just my opinion, obviously, but I happen to think Mobil is nothing special at all. Many oils exist out there that show far better looking UOAs than what Mobil does. And this has been the case since I joined the site way back in 2006, which begs the million dollar question, (that no one can seem to answer) why? “
Irv,
nobody can answer a question that is in fact personal opinion. Your opinion is that M1 is not as good as some other brands and you have the right to that opinion.
But I don’t think you or anyone else can come up with a scientific explanation as to why.
Years ago I tried Mobil 1 in a Mitsu 3.0 and it ran noisier compared to the Castrol Syntec I had been running. Why? I’ll never know but I switched back to Syntec on the next change. I do think M1 is a quality product but sometimes certain engines “dislike” an oil for mysterious reasons. Run your favorite brand and be happy.
I'm not sure how my question is a personal opinion, Pimtac, when I am talking about this UOA and others that I have seen on here for a long time?
I am also stumped/confused, like you, I assume, with so much scientific analysis/info/data available, that no one can come up with a reasonable/scientific explanation for this? Something has to be in the oil, or not in the oil, to cause this so it's surprising the answer hasn't been found, or shared, that I have ever seen before?
Originally Posted By: Artem
Certain engines dislike certain oil additives, that's for sure. That's the only way to explain the unusual wear vs another brand of the same viscosity. OIL additives matter.
I agree, some oils work better than others, but with the Mobil UOAs I see, the variety of engines/vehicles is broad. If it was a notorious bad oil, say, for a SBC for example, and nothing else, there would be a scientific/mechanical explanation for it, but since I see it in a broad variety of vehicles/engines, imo, there is something definitely going on with it.
Regardless, and like what, Pimtac said, that answer seems elusive and likely will be, (even though I believe one exists somewhere), for sometime yet it seems.
For those that use and like it, good for you, carry on, I just know it's not the oil for me and likely won't be anytime soon.
