First off-thanks for the replies.
Now, why do you think your Toyo loved M1 enough to actually drink the stuff?
Ideas?
Scott
Ideas?
Scott
The GL-4 is not used to "gain" anything. It's used for compatibility reasons, at least in some transmissions. For example, the VAG trannies contain brass synchros which are easily damaged by the EP additives in typical GL-5 gear oils (Mobil 1 75w-90). That is why I was asking if he knows if the car is OK with GL-4/GL-5 or if GL-4 specifically must be used. Most cars are OK with it.quote:
You really do not gain anything with Toyota manual transmissions buy useing a GL4 only fluid in most cases.
Bill,quote:
3. My Dads 2001 Civic needing a new long block at 14k miles.
He had always had a good leak. The local Honda Dealer (quote:
Why did it need a new block, what happened
