Originally Posted By: JGmazda
Originally Posted By: HoosierJeeper
Checkout some of the Liberty forums.
02s had valvespring issues, otherwise they're great, just don't overheat them. Many have hit 300k without issues. Keep clean 5w30 of whatever you like in them.
PS fluid is ATF+4 for 03+, 02s had something weird but got back spec'd to ATF+4.
They're very easy to work on. Stock suspension is trash, was when new too so I replaced mine with Old Man Emu stuff and it rides as good as my LR3 and better than my new Cherokee. I have 167k on mine. Love it. The biggest issue was I did have to get the trans rebuilt last summer (failed TC), so make sure yours has a service history regarding the trans. Most people don't have an issue, but it's worth bringing up. 08+ is a different era, largely the same, just a little bigger and they went to a 5 link rear suspension and not 3. Electronic shift t case too.
- Great information HoosierJeeper! What year do you own? What was the approximate cost of the transmission fix and is it a better transmission build? Also, can you tell me more about the suspension upgrade?
Originally Posted By: fcjeep
As far as coolant, Zerex G-05 and dealer coolant (make sure they give you the right stuff) is all I ever found available.
AFAIK power steering fluid is also a specific spec. No one has it except the dealer. $18 a qt I think last time I bought but you don't need it too often. I know about Mag-Moss but no one else has it as of last time I checked.
- Thanks fcJeep! Zerex G-05 is all I have used in my Mazda for some time. Good stuff! I will look into the power steering fluid.
Mine is an 05...got it back in 07.
Basically, new springs and shocks. The factory spring rate is too weak and gives a rough ride. It sags too. By 79k miles, mine had sagged 1.5" from new. Measure from the hub to fender flare, new should be 19".
Old Man Emu is one of the best life manufacturers. Checkout jeepinbyal.com to see all the lifts for these. It rides so much better...I was going to trade it in until I lifted it.
The trans rebuild was like $4000. There were some upgrades the shop did but I can't remember them, mostly small things.
