I suspect that when you do drop the pan, it’s going to look a lot like this engine. 234,000 miles, run mostly unconventional. Engine doesn’t burn any oil however, look around each one of the bolts, the lighting on this one is bad, but you can see the ton of carbon that was built up.
I cleaned this one up by hand, and stuffed rags in and around the crank so that any stray gunk that I cleaned off would not end up lingering in the engine.
I used Volvo anaerobic sealant, and after resealing it, I filled it with Mobil 1 and ran for a bit. Then flushed it with LiquiMoly engine flush.
Then, naturally, I refilled it with HPL.
I suspect the oil filter will be fairly loaded up when I change it.
The engine still doesn’t use a drop of oil, and it runs great.
