Quote:
And what is the normal flow rate for the PSD with a 1/16 orifice and 1/4" diameter hose?
I would guess around a 1 quart/minute at hot idle.
steved
Quote:
luckydog I find it kind of funny that they give out different numbers to different people!!!??? kinda made me laugh when you posted that. if the b164 were 2 micron absolute I would run it in a heart beat. even though I already got a Frantz ready to install. Maybe some more emails to baldwin are in order. somebody else want to email them and see what you come up with. here is the email address
[email protected]
I also agree that it could very easily be a streak. I would not get overly concerned with the UOA yet. How many miles are on the oil you are running so far? even with the filter if you are close to the same amount of mile you would have run the oil without the bypass then you are fine. Its not the filter fault for the lead findings.
Quote:
griz I don't know if oil will come out of the port on the block. you could get a pipe plug to plug the hole then start it up to check. not sure what the normal flow rate is but the full flow filter I run is rated for 30 some GPM. the wix are rated for 17 GPM
Quote:
same person same company 2 very different replies???? well how know which way is up now. other than both replies told me that the absolute rating is 15 micron.
Quote:
Griz, start a thread in the UOA section the same way you started this one. All you have to do is manual type in all the numbers off the UOA that you've received. You don't need to attach pictures.
Quote:
I must be a computer dummy or something. I have seen others who have posted them but can't figure it out myself.
Griz95
