It has long been written that you can expect the same protection from dino juice as you can from synthetic over short to moderate intervals (3000-5000 miles), disregarding temps below -20. Along with this it has been written that the major advantage to using a synthetic or "diesel" oil is that they will keep your engine cleaner verses a "regular" dino.
As far as I can tell the reason for this would be the typical synthetic (mobil, GC) has alot more calcium (detergent) that a regular dino. The "diesel" oils also have a very healthy does of calcium when compared to plain dino juice.
The reason I am making this observation, nobdy seems (to me at least) to place a high value on calcium, as apposed to zddp, moly, boron. What is an acceptable amout of calcium to have in an oil?
I have also noticed that the new GF4/sm oils have a reduced calcium levels when compared to GF3 oils.
Some examples pulled from the VOA section.
Phillips Trop Artic 5w-30 API SM
Calcium 1521
Motorcraft 10w-30
Calcium 2077
New GF-4 Mobil 1 5w-30
Calcium 2500
Mobil-1 5W-30 SuperSyn
Calcium 2971
Pennzoil 10W-30 sl
Calcium 2060
Pennzoil 10w-30 API SM - GF-4
Calcium 1763
Calcium 1521
Motorcraft 10w-30
Calcium 2077
Calcium 2500
Calcium 2971
Pennzoil 10W-30 sl
Calcium 2060
Calcium 1763
