Just for the record, there's a limit to how low you can go with regards to Noack. Even if you happen to have a base oil with close to zero Noack, you will usually get a positive net contribution to Noack from both the DI & the VII. Part of this will come from the diluent oil in both. Most additives are habitually thick and need thinning down to make them handleable. Also some common type of components blended into the DI package are themselves partially volatile at 250°C (ZDDP for example). Furthermore you also get some components that are downright weird like Phenolic AOs which have zero volatility but exhibit 100% volatility when blended into fully formulated oils.
