Marvel Mystery Oil... previously answered... sorryMMO?
I use non-ethanol regular in my riding mower, pressure washer and any 4 cycle small engine. For all of my 2 cycle stuff, I use non-ethanol premium. What gas additives are y’all using for your lawn mowers, string trimmers and other lawn and 2 cycle equipment? I’m looking for something that keeps fuel fresh and contains a cleaner. I’m trying to get away from Sea Foam because of the amount of alcohol it contains.
I wonder what the octane rating of the gas is after you do this. My bet is it is quite low. Small engines may not care, but I wouldn't run it in a car.I take 93 E10 to five gallon gas can with a bottom drain spout. Add 32 oz of water with blue food coloring. Shake it up. Let it sit for a few hours. Drain the water out. Ethanol and water mix together but the fuel doesn’t. The lawnmower and my Sthil love it.
Probably around 91 given that 10% ethanol is used to bring 85 to 87 octane. As long as all the water is removed it shouldn't be a problem.I wonder what the octane rating of the gas is after you do this. My bet is it is quite low. Small engines may not care, but I wouldn't run it in a car.
I’ve been told it drops 3 points.I wonder what the octane rating of the gas is after you do this. My bet is it is quite low. Small engines may not care, but I wouldn't run it in a car.
