Originally Posted By: aquariuscsm
Originally Posted By: Linctex
Originally Posted By: kschachn
Originally Posted By: L_Sludger
There have been lawsuits over the meaning of synthetic oil. Now synthetic can mean anything, it seems.
No, there haven't been.
There was this:
http://www.syntheticwarehouse.com/Press%...0in%20court.pdf
" The National Advertising Division of the Council of Better Business Bureaus
serves as the dispute resolution mechanism for U.S. advertisers. Disputes often
break out over advertising — or rather truth in advertising — so NAD’s function
is to review factual claims made in national advertisements and where necessary,
resolve disputes between the parties. In such cases, NAD typically reaches a conclusion
within 90 days of a filing. Lest you think this is an easy way to complain about
an ad that you don’t like, you’ll find there are some basic requirements which
include pretty hefty filing fees: $5,000 andup, depending on company size. (Companies
with revenues over $1 billion will pay four times that.) Compliance with NAD’s findings
is voluntary, and its decisions can be appealed (after paying another fee).
The court determined that Pennzoil was wrong and was required to remove the
advertising from both television and print media. At this point, I guess you
could say that the two companies were even.
In March 1999, NAD came to one of its most far-reaching decisions ever. Castrol
was challenged by Mobil Oil Corp. (now ExxonMobil) over statements that Castrol
Syntec Engine Oil was both superior and synthetic. Previously, Castrol had used
polyalphaolefin base stock in Syntec, but of late it had switched to hydroisomerized
mineral base stocks. These, Castrol’s experts argued, could be labeled
synthetic because hydroisomerization changes the oil’s linear paraffin into a
branched-chain one, through the use of an intended chemical process and a solid catalyst.
To Mobil’s dismay, NAD found this persuasive. While NAD rejected Castrol’s claims of
“superiority” for Syntec, it concluded that the oil marketer had a reasonable
basis for asserting that hydroisomerized base stocks are synthetics.
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=950311
"One thing people forget is that after the ruling that Castrol was not out of bounds calling Group III base oils "synthetic" every major oil company switched their base stock to the more profitable Group III. That is except for Mobil 1. Maybe Mobil refused to accept the ruling. No matter. What followed was a disaster for the average consumer especially those driving German cars still under warranty. Here's why:
People driving Germain cars, BMW, Mercedes, Volkswagen, were required to use certain spec oils to remain under the manufacturer's warranty. These same owners noticed the name "Castrol Synthetic" on the expensive oil the Dealer was installing and many decided to save money and have Castrol Syntec installed at a local lube center or maybe did it themselves at home. What was worse, some of these cars had extended oil drain intervals up to 20,000 miles. What followed was a lot of sludging and engine damage with a lot of people being told their warranty was voided. The reason there was so much confusion is the motor oil sold at the Dealership service department were European Group IV synthetics that had been certified by the manufacturer for use in those engines. Castrol Syntec not only is Group III, but not certified for use in those engines.
I hate to say it, but the use of Group III "synthetics" needs to be rated differently somehow. Not only are these motor oils petroleum, but being petroleum they must employ lots of VI additives for for the "W" or winter grade specs."
What's so ironic about Mobil doing this to Castrol,Mobil themselves went to a group 3 oil. There's a "secret" paper floating around on the net somewhere where ExxonMobil says something to the effect of changing from a pao base to a group 3 base aka Visom behind the public's back,but that paper got leaked out somehow haha.
All M1 oils are a blend of base stocks of grp 3+, PAO, and esters, and maybe other goodies. Anyway their oils certainly perform very well over the long haul. And has been said, it's performance that counts.
