Originally Posted by ABN_CBT_ENGR
Originally Posted by Triple_Se7en
I've seen too many crooked or half-blocked louver photos at this place, to have more-than-enough reason to avoid them. So I would hate to see Fram become louverish too.
The small eyelid louvers annoy me. The big round holes are OK. I';d use one of those in a pinch. Lately I've been using AC Delco Ecore again. Want to try Fram Ultra next
I generally gloss over the filter discussions here over the years ( other that the autopsy ones- they are cool) but maybe should have read more.
I'm not sure what crooked or half blocked means colloquially (angled say on a Z axis relative to flow and a semi closed[metering] as opposed to fully open?
But in a nominal filtration design with all other things being equal- both of those are superior components of a well designed filtration path ( based on the filtration strategy ) than the traditional orifice (hole) would ever be ( or could be)
Beauty is in the eye of the beholder but if high end filtration and retention over time is desired (with flow being equal in terms of delta) in the same space or area, the louver design is superior by orders of magnitude.
He's talking about this. Not all louvers are created equal - louvers are only "superior" if formed correctly.
Which filter would you use between the two shown below? People just need to inspect the center tube for correctly opened up louvers before buying a filter with louvers.
Bad Louvers
Good Louvers
